[ X ] Android
Obsidian Mobile version: v1.0.3.
When browsing long files in preview mode it would be great to be able to go to the end/beginning of the the file, like you would in editor mode with “Go to first line” or “Go to last line”
Specially since files don’t remember your place , and will start at the beginning; if the file is long it can be a bit tedious to scroll, even with pressing and dragging, all the way to the end.
Edit: Originally thought the press and drag didn’t work because I couldn’t get it to move, turns out my fingers are a bit big to press the small scrollbar correctly, so maybe making the scrollbar a bit bigger would make it easier to press.
