We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
open blank document
input something
specificly type very fast
It seams fine in appimage, and not works in flatpak
This is appimage debug info
Obsidian version: v0.14.5
Installer version: v0.14.5
Operating system: #1 SMP PREEMPT Sat Apr 9 06:30:15 UTC 2022 (b49cf22) 5.17.2-1-default
Legacy editor: off
Base theme: light
Safe mode: off
Plugins installed: 9
Plugins enabled: 9
1: Kanban
2: Dataview
3: Advanced Tables
4: Calendar
5: Excalidraw
6: QuickAdd
7: Mind Map
8: Pandoc Plugin
9: Markdown Table Editor
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the help vault or disable community plugins.
