Thanks, but where can I see the list and download link of plugins for manual install?
Besides, my Mac OS has no other firewall installed and I also tried to use my iPhone as hotspot (should have no firewall, right?), still can’t get any community plugin from “browse”
where in the world are you? can you access github.com?
If you are in china, you are behind “the great firewall”.
Oops, thanks…
Just checked that I can access github.com site. So is there any workaround to download and install the plugins?
me too, did you solve your problem , how?
Use VPN~ :joy:
Use VPN and restart obsidian :joy:
Thanks , with VPN , problem solved !
Thanks! It works!
