Failed to authenticated: vault not found. across Mac devices
Trying to Sync across devices.
I have set up my vault and personal token which I made in obsidian, however I keep getting the following error in the sync log failed to authenticated: vault not found.
This is between my mac mini, primary comp, and my mac book, I get the sync error from my mac mini.
I have checked to make sure syncing is occuring but dont know why my primary computer has this error, I see my vault perfectly in the side bar, however, the vault on my macbook is out of date, over a week possibly a month ago.
Please help!!!
I don’t know the answer but you can get direct support by emailing [email protected].
I had a similar issue with mac and iOS. Disconnecting from the remote vault then reconnecting fixed the issue.
