F3/cmd+g 'Find next' and 'Find previous' hotkeys can be triggered even if the active pane is different
  1. Open 2 separate notes in different panes, side-by-side
  2. Run a fnd command (ctrl+f) for a phrase in note 1. It doesn’t matter what it is.
  3. Switch focus to note 2 and run a find command for another phrase.
  4. Then switch focus back to note 1.
  5. Press the F3 keyboard shortcut to jump to the next search result.
  6. You would expect the search to run in note 1, which has focus. However, it will jump to the next search result in note 2, which does not have focus.
We would expect to see the F3 next search result to run in the pane with focus.
Instead, it will jump to the next search result in the note which has most recently run the find command.
  • Operating system: Windows 10 Home and Pro
  • Obsidian version: 0.12.19
Reproduced on MacOS as well. Obsidian 0.13.3
This is causing Issues with my go-to-line Plugin which is using Ctrl + G by default, like most other editors. This is mostly used for improved accessibility, e. g. people who use their device using Voice Commands.
will be fixed in 0.13.27
