Have you looked at Note Refactor plug-in? It is doing that and is totally awesome. You should just select what you want to be moved, whether it is just one heading or more.
hi, with the note refactor plugin
what code should i use if i want the new note name will be the - original note name + the first line of the part i cut?
thank you
It would be nice to add file name suffixes: {{title}} {{new_note_title}} or {{title}} {{date}}
It could be implemented also to create relative paths {{title}}/{{title}} {new_note_title}}.md
This will be implemented in 0.12.6
