- paste or drag an image into a note so it’s visible on preview (exclamation mark and double brackets)
- click ‘more options’ button and then click export to PDF option
- chose settings, click ‘export to pdf’ button
- chose file name and destination folder
- click ok
- get a pdf with the image on the chosen folder
- no pdf
- error message on upper right corner saying “Failed to Save PDF.”
- following error message on dev console log:
TypeError: Cannot convert undefined or null to object
at hasOwnProperty (<anonymous>)
at PreviewDatabaseModeService.eval (plugin:dbfolder:132873)
at Generator.next (<anonymous>)
at eval (plugin:dbfolder:41)
at new Promise (<anonymous>)
at __awaiter (plugin:dbfolder:37)
at PreviewDatabaseModeService.markdownPostProcessor (plugin:dbfolder:132861)
at Function.e.postProcess (app.js:1)
at e.<anonymous> (app.js:1)
at app.js:1
(anonymous) @ app.js:1
- Operating system: Windows 10 Pro
- Debug info:
Obsidian version: v0.14.15
Installer version: v0.13.23
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Safe mode: off
Plugins installed: 4
Plugins enabled: 3
1: DB Folder
2: Dataview
I can export PDFs without images normally.
It happens just as same with Pandoc, even when trying to export to docx.
The following printscreen shows first attempt without pandoc enabled, second attempt with pandoc enabled but using regular ‘export to PDF’ and third using pandoc command to docx
