Expanding a collapsed code block line loses classes after restart
  1. Create a note and place the following code snippet in the note.
```python
if x:
	if y:
		func()
	else:
		another_func()
  1. Collapse the second code line if y:.
  2. Restart Obsidian.
  3. Expand the second line.
Y
The expanded code line should have proper syntax highlighting.
Syntax highlighting for the expanded code line is gone.
In more technical words, it lost the CSS classes as it only has class cm-line instead of classes HyperMD-codeblock HyperMD-codeblock-bg cm-line.
	Obsidian version: v1.5.8
	Installer version: v1.5.8
	Operating system: Windows 10 Pro 10.0.19043
	Plugins installed: 2
	Plugins enabled: 0
Tested in Ubuntu and Windows.
expanded code block syntax highlight bug
