Execute Templater Script in Callout
I have created this template to insert 5 random notes with incomplete status tag into my daily notes for me to process, which works perfectly. However, I now also want to have it be inserted into a folded callout box, so that the 5 notes are hidden until I open the callout. I have attached a screenshot of what it should look like after the template code.
The template:
const noOfNotes = 5
const dv = this.DataviewAPI
const files = await dv.tryQuery
   LIST
   WHERE status = "incomplete"
let randomList = []
for (let i = 0; i < noOfNotes; i++) {
  const random = Math.floor(Math.random() *
                            (files.values.length - 1))
  randomList.push(files.values[random])
tR += dv.markdownList(randomList)
What it looks like currently, without any callouts in the template:
What I want (note the blue callout box around the section):
I have tried searching, but everytime I mention templater & callouts together all I can find are templates to insert callouts.
I have tried adding “>” before all lines, before just the dv.tryQuery parts - ending at “`)”.
I also tried this with a dataview command like below, which works as I want, although I want the results to be printed with templater, so they do not refresh each time I open the note:
The template
> [!5 Random Notes (Dataviewed)]
>  ```dataview
>   LIST
>   Limit 5
This returns:
The Issue
It seems like templater can’t recognise commands with a “>” in front of them, unlike when doing the same thing with dataview. I can’t really figure out a solution with my limited knowledge of Templater & js
Note, your logic doesn’t protect against duplicates. Here is a quick version that I ran on my Book collection for status = "unread". A bit brute force, but it works.
const noOfNotes = 5
   LIST
   WHERE status = "unread"
let randomList = []
tR += '> [!unread]-\n'
  tR += '> ' + files.values[random] + `\n`
Hey thank you so much for this! that is fantastic :slight_smile:
