Exclamation mark in folder name creates problems
Steps to reproduce\
  1. Create a new vault
  2. Create two directories “!A” and “B” in root
  3. Publish both
  4. Create directory “A”
  5. Publish “A”
  6. Unpublish everything (does not really work)
  7. Delete publish site (does not really work()
Sort of. When I did this, the problem went away.
Remove files.
Did not remove files.
I published the vault, then deleted the site, then added the site, then published and the problem went away. I think that there is an underlying problem involving question marks though.
In the bug report template you’re asked for “Environment” and the “show debug info” output. I think that would be helpful here.
