I would like to suggest that pressing ESC while a popup menu is active should close it. This is pretty standard UX across most apps/OS platforms.
Here are some examples of the popup menus I am referring to:
File explorer → right click on a note
Note editor → right click on a [[link]]
“Three dots” menu at top right corner of note
There are many others, but you get the idea.
