Enable use/access to hidden files and folders starting with a dot /dotfiles/.dotfolders within Obsidian
Same for me, using folder bridge with a slightly modified source to allow a Linux or Mac fallback Mount point and faster mounts for larger mounts
Submitted a PR to original repo, hopefully it gets approved
Allowed me to
and
The only issue I find with Folder Bridge is on IOS it doesn’t work so you can’t access dot folders from it. I don’t understand why this isn’t a feature from obsidian, you should be able to control what shows in obsidian, this is a simple feature that kills obsidian for llm management.
I’m guessing the primary reason was so that you can’t modify/break your .obsidian folder which contains all your Apps settings.
When Obsidian was first released Claude didn’t exist
Could be a setting in the future to allow other hidden folders (just not .obsidian)
