Obsidian Publish doesn’t respect frontmatter (note properties) fields. They are not displayed or used for link navigation once the vault is published online.
I am trying to use existing notes properties (which represent relationships between notes, tags etc) to replicate the same structure as my local vault in the published version, but Obsidian Publish ignores note properties thus breaking links.
I’d also like the tags to be displayed and navigatable just like they are in the app.
Make Obsidian Publish display note properties (could be toggle-able for those that don’t want that).
Make Obsidian Publish understand the links in note properties and use them to present relationships between notes (currently only in-line links are respected).
There are some hacks I’ve seen in the forum but nothing seems to work well enough to be an accepted solution.
