Embedded bases with tens of entries not rendered
I have some bases with tens or 100+ entries that are “rendered” with no problem when I open the base file while when I see the same base file embedded in another note it just shows the first 15/20 entries and after a great blank space: for example I have a base with a filter that returns 29 entries (and this is the number shown also in the embedded base) but it just shows 16 entries).
For the moment I’ve decided not using bases in such context (ie: where I know that the results can make this happen, but I’m wondering if it’s a common issue and if it can already be solved
thanks!
