Embedded base reloads entries on first open
  1. Open a new sandbox vault
  2. Create a new base
  3. Create a new note
  4. Embed base in the note
  5. Go to any note that doesn’t contain the embedded base
  6. Open developer settings, go to “Performance” and set CPU throttle to 20x
  7. Open the note with the embedded base inside
Did you read and follow the Troubleshooting Guide ? Yes
The base should load once.
The base loads all entries, then clears them and reloads all of them again.
Obsidian version: 1.14.3
Installer version: 1.13.7
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
Using CPU throttling is the only way to make this show in a sandbox vault, because it happens so fast. It is very noticeable without throttling in my main vault.
20260930-1016-57.0050266-ezgif.com-video-to-gif-converter
thanks
will be fixed in v1.14.4. ETA unknown.
