Emacs-style (C-n / C-p) navigation within command palette
Smallish request! Can you add C-n and C-p keybindings for cycling through the command palette, quick complete, and quick-switcher menus?
It’s fairly standard across apps that I use so I get surprised when it’s not there :smile:
This would be absolutely fantastic.
It’s very annoying to have to move my hands from the home row just to select a file :D.
I’m curious which OS you’re on. I forget how I did it exactly, but I’ve enable limited emacs keybindings globally on macOS. So C-n and C-p work for cycling through the command-palette. Also C-a and C-e to jump to the start and end of the line are very handy
I’ve also remapped CAPSLOCK to the Ctrl key, and I use pseudo emacs keybinding C-3 and C-2 to split screen vertically and horizontally, respectively
Privatly I’m on Linux, however at work I use Windows and won’t be able to tweak it too much.
Could you please list the option needed for accessing emacs keybinding on macOS? I can access emacs keybinding in other apps but not in obsidian command palette.
I use BetterTouchTool to enable them globally
