Can’t use more than one setting for text in Editing Toolbar.
Thought it would be an easy thing, but it doesn’t work, can change font color or make it bold, but not on the same text.
Thought it was because of the Things theme, but the issue is with the plugin.
Installed the Fast Text Color plugin and doesn’t use font color tags.
All options are available in a context menu and to change the color (or remove) you only need to click the colored text once and hover over the colored disk.
