Edit-mode in page preview does not apply cssclasses
Add any class name to the cssclasses property of a note and target them via user styles.
As in the regular reading and editing view, I’d expect my cssclasses to be added to the page preview container in both the reading and edit-mode.
They are applied to the reading view of the page preview, but not when I activate the edit mode by clicking on the preview.
Obsidian version: v1.8.7
Installer version: v1.8.4
Operating system: Darwin Kernel Version 24.3.0: Thu Jan 2 20:23:36 PST 2025; root:xnu-11215.81.4~3/RELEASE_ARM64_T8112 24.3.0
Catalyst license: none
Snippets enabled: 2
Plugins installed: 1
Plugins enabled: 0
I’ve moved this to Custom CSS & Theme Design for now
Whether this is a bug or CSS help, it would make sense to share the CSS code you’re trying to use, including the cssclasses property you have set, so people can help you, or so a bug can be reproduced and verified.
For example, using this CSS:
.dark-note-rises {
    background-color: rgba(68, 68, 38);
    --text-normal: rgb(209,209,209);
    color: var(--text-normal);
    --metadata-input-text-color: limegreen;
    --h1-color: salmon;
and dark-note-rises as a cssclass in a note, I can see the behavior.
vivaldi_fENkJdDc5j
Editing in Page preview popups is fairly recent, so this many not be implemented yet.
Not the same issue (I don’t think), but there’s a semi-related feature request here:
