A frustrating irk of Obsidian is constantly toggling between reading and editing modes – either trying to edit while in reading mode, or forgetting to switch to reading mode when just browsing. Visually conflicting icons certainly don’t help. This little irk of mine turned into a totally-not-worth-the-time-investment ‘development’ of a custom plugin while possessing zero coding knowledge, w/ the help of a little chatbot you might’ve heard of. Thank goodness for AI assistance!
I find that this works (and looks!) best w/ Minimal Theme’s Undeline tab style (shown above), which can be enabled in its Style Settings, and w/ Colorful active states, which can be enabled in Minimal Theme Settings.
I’ll just share the plugin’s main.ts here to save someone a few hours of their life if the same idea strikes them. Feel free to use the code however you want–including turning it into a full-blown community plugin!
If you’re someone like me, you can get this up and running in five minutes–just ask for guidance from your nearest chatbot.
main.ts
main.ts.zip (2.8 KB)
import { App, Plugin, PluginSettingTab, Setting, MarkdownView } from 'obsidian';
interface AccentColorSettings {
sourceColor: string;
livePreviewColor: string;
readingColor: string;
darkSourceColor: string;
darkLivePreviewColor: string;
darkReadingColor: string;
const DEFAULT_SETTINGS: AccentColorSettings = {
sourceColor: '',
livePreviewColor: '',
readingColor: '',
darkSourceColor: '',
darkLivePreviewColor: '',
darkReadingColor: ''
const DEFAULT_HSL: [number, number, number] = [250, 100, 50];
// Define settings keys as constants to ensure consistency
const SETTING_KEYS = {
sourceColor: 'sourceColor',
livePreviewColor: 'livePreviewColor',
readingColor: 'readingColor',
darkSourceColor: 'darkSourceColor',
darkLivePreviewColor: 'darkLivePreviewColor',
darkReadingColor: 'darkReadingColor'
} as const;
export default class AccentColorPlugin extends Plugin {
settings: AccentColorSettings;
async onload() {
await this.loadSettings();
this.addSettingTab(new AccentColorSettingTab(this.app, this));
this.registerEvent(this.app.workspace.on('active-leaf-change', () => this.updateAccentColor()));
this.registerEvent(this.app.workspace.on('layout-change', () => this.updateAccentColor()));
this.registerEvent(this.app.workspace.on('css-change', () => this.updateAccentColor()));
this.updateAccentColor();
async loadSettings() {
const data = await this.loadData() || {};
const cleanSettings = { ...DEFAULT_SETTINGS };
// Create a map of all possible key variations to their canonical forms
const keyMap = new Map(Object.values(SETTING_KEYS).flatMap(key => [
[key.toLowerCase(), key],
[key.toUpperCase(), key],
[key, key]
// Normalize all keys in the data
for (const [key, value] of Object.entries(data)) {
const canonicalKey = keyMap.get(key);
if (canonicalKey && canonicalKey in cleanSettings) {
cleanSettings[canonicalKey as keyof AccentColorSettings] = value as string;
this.settings = cleanSettings;
// Always save with canonical keys to clean up any legacy data
await this.saveData(cleanSettings);
async saveSettings() {
// Ensure we're only saving the canonical keys
const cleanSettings: AccentColorSettings = {
[SETTING_KEYS.sourceColor]: this.settings.sourceColor,
[SETTING_KEYS.livePreviewColor]: this.settings.livePreviewColor,
[SETTING_KEYS.readingColor]: this.settings.readingColor,
[SETTING_KEYS.darkSourceColor]: this.settings.darkSourceColor,
[SETTING_KEYS.darkLivePreviewColor]: this.settings.darkLivePreviewColor,
[SETTING_KEYS.darkReadingColor]: this.settings.darkReadingColor
isDarkMode(): boolean {
return document.body.classList.contains('theme-dark');
updateAccentColor() {
const activeView = this.app.workspace.getActiveViewOfType(MarkdownView);
if (!activeView) return;
const mode = this.detectMode(activeView);
const isDark = this.isDarkMode();
let color: string;
if (isDark) {
if (mode === 'livePreview') {
color = this.settings.darkLivePreviewColor || this.settings.livePreviewColor || '';
} else if (mode === 'source') {
color = this.settings.darkSourceColor || this.settings.sourceColor || '';
} else {
color = this.settings.darkReadingColor || this.settings.readingColor || '';
} else {
color = this.settings.livePreviewColor || '';
color = this.settings.sourceColor || '';
} else {
color = this.settings.readingColor || '';
if (!color.trim()) {
const [h, s, l] = DEFAULT_HSL;
document.body.style.setProperty('--accent-h', h.toString());
document.body.style.setProperty('--accent-s', s + '%');
document.body.style.setProperty('--accent-l', l + '%');
return;
if (!color.startsWith('#')) {
color = '#' + color;
try {
const [h, s, l] = this.convertToHSL(color);
} catch (e) {
detectMode(view: MarkdownView): 'source' | 'livePreview' | 'reading' {
const sourceView = view.contentEl.querySelector('.markdown-source-view');
const readingView = view.contentEl.querySelector('.markdown-reading-view');
if (readingView && window.getComputedStyle(readingView).display !== 'none') {
return 'reading';
} else if (sourceView) {
return sourceView.classList.contains('is-live-preview') ? 'livePreview' : 'source';
return 'source';
convertToHSL(color: string): [number, number, number] {
return DEFAULT_HSL;
const temp = document.createElement('div');
temp.style.color = color;
document.body.appendChild(temp);
const computedColor = getComputedStyle(temp).color;
document.body.removeChild(temp);
if (computedColor === 'rgb(0, 0, 0)' && !color.match(/black|#000|rgb\(0,\s*0,\s*0\)/i)) {
return DEFAULT_HSL;
const rgb = computedColor.match(/\d+/g)?.map(Number);
if (!rgb || rgb.length !== 3) {
return DEFAULT_HSL;
const [r, g, b] = rgb.map(v => v / 255);
const max = Math.max(r, g, b);
const min = Math.min(r, g, b);
let h, s, l = (max + min) / 2;
if (max === min) {
h = s = 0;
} else {
const d = max - min;
s = l > 0.5 ? d / (2 - max - min) : d / (max + min);
switch (max) {
case r: h = (g - b) / d + (g < b ? 6 : 0); break;
case g: h = (b - r) / d + 2; break;
case b: h = (r - g) / d + 4; break;
default: h = 0;
h /= 6;
return [Math.round(h * 360), Math.round(s * 100), Math.round(l * 100)];
class AccentColorSettingTab extends PluginSettingTab {
plugin: AccentColorPlugin;
constructor(app: App, plugin: AccentColorPlugin) {
super(app, plugin);
this.plugin = plugin;
display(): void {
const {containerEl} = this;
containerEl.empty();
containerEl.createEl('h2', {text: 'Light Mode Colors'});
this.addColorSettings(containerEl, false);
containerEl.createEl('h2', {text: 'Dark Mode Colors'});
this.addColorSettings(containerEl, true);
private addColorSettings(container: HTMLElement, isDark: boolean): void {
const modes: ('source' | 'livePreview' | 'reading')[] = ['source', 'livePreview', 'reading'];
modes.forEach(mode => {
const settingKey = isDark
? `dark${mode.charAt(0).toUpperCase() + mode.slice(1)}Color` as keyof AccentColorSettings
: `${mode}Color` as keyof AccentColorSettings;
new Setting(container)
.setName(`${mode.charAt(0).toUpperCase() + mode.slice(1)} Color`)
.setDesc(isDark ?
`Set the accent color for ${mode} mode in dark theme (Leave blank to use light theme color)` :
`Set the accent color for ${mode} mode in light theme`)
.addText(text => text
.setPlaceholder(isDark ? 'Enter color or leave blank' : 'Enter color')
.setValue(this.plugin.settings[settingKey])
.onChange(async (value) => {
this.plugin.settings[settingKey] = value;
await this.plugin.saveSettings();
My color scheme
Light
Source - #379d94
Live Preview - #97698c
Reading - #6b987d
Dark
Source - #52c4bb
Live Preview - #c790b3
Reading - #8cbf9e
Optional CSS snippet to hide border under "Underline" tabs--for a cleaner look, best paired w/ "Workspace borders" toggled OFF in "Minimal Theme Settings"
[Minimal] Hide border under tabs for “Underline” tabs.css (904 Bytes)
body.theme-light.tabs-underline .mod-root .workspace-tab-header-container,
body.theme-dark.tabs-underline .mod-root .workspace-tab-header-container {
border-bottom: none !important;
body.theme-light.tabs-underline .mod-left-split .workspace-tab-header-container,
body.theme-dark.tabs-underline .mod-left-split .workspace-tab-header-container {
body.theme-light.tabs-underline .mod-right-split .workspace-tab-header-container,
body.theme-dark.tabs-underline .mod-right-split .workspace-tab-header-container {
body.theme-light.tabs-underline .workspace-tab-header-container,
body.theme-dark.tabs-underline .workspace-tab-header-container {
body.theme-light.tabs-underline .workspace-tab-header,
body.theme-dark.tabs-underline .workspace-tab-header {
border-bottom-width: 2px;
