For me, oftentimes groups will be moved all over the canvas. However the nodes that the groups are connected to may stay in one place, or not. Regardless, it regularly occurs that the group’s anchor, that I originally chose to attach the connection line to, becomes a less than ideal choice, causing the connection line to run through the entire group. I can remove the connection line and reattach it to a better anchor, but even this is a temporary solution.
It would be nice if there were an option to have connection lines for groups be dynamic, automatically attaching to the nearest anchor.
Draw.io has a nice solution for that. They give you the ability to either connect to a specific anchor (at which point there is no dynamic behaviour), or connect to the node itself (by dragging the connection line anywhere else on the node itself. If the second option is used, the anchor point becomes “shortest path” and is dynamic.
I hope we get to see a similar system put 8n place!
Great feature request!
For now you can also click on the connection line and simply drag one end to another connection point of your card - maybe this helps a little, in case you didn’t know that already
I thought that maybe it was less realistic for it to be implemented for all nodes and thought maybe doing it for groups might be a starting point. Feel free to merge them. Thanks.
Sometimes I wish Obsidian could make and maintain the choice of node anchors with which the canvas connection lines are attached.
It would be helpful in some cases to be able to turn on a dynamic anchor mode to let the nearest anchor always be used in order to make a connection between two canvas nodes.
+1. I’ve been using the canvas feature to divergently/ spatially think through things. I end up updating a lot of arrows as things become clearer and as I prepare the canvas to share with others.
