"Duplicate current file" or "Duplicate" in right-click menu no longer works
  1. Open Sandbox vault.
  2. Right-click on the name of an existing note in the Files left-hand sidebar (e.g., “From plain-text note-taking”).
  3. Select “Duplicate” in the menu.
  4. No duplicate note (e.g., “From plain-text note-taking 1”) appears in the Files left-hand sidebar.
Note: The same thing happens when using the “Duplicate current file” command from the Command palette.
Did you follow the troubleshooting guide? [Y/N] Y
I expected to see a duplicate of the desired note.
I did not see a duplicate of the desired note.
Obsidian version: v1.8.0
Installer version: v1.6.7
Operating system: Darwin Kernel Version 24.1.0: Thu Oct 10 21:02:27 PDT 2024; root:xnu-11215.41.3~2/RELEASE_X86_64 24.1.0
Catalyst license: supporter
Insider build toggle: on
I get one of the following errors in the Developer Console every time I try to duplicate a note (via either method):
app.js:1 Obsidian Developer Console
node:internal/bootstrap/realm:428 Uncaught (in promise) TypeError: Missing internal module ‘original-fs/promises’
at requireBuiltin (node:internal/bootstrap/realm:428:19)
at node:internal/original-fs/cp/cp:48:5
at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
at requireBuiltin (node:internal/bootstrap/realm:429:14)
at lazyLoadCpPromises (node:internal/original-fs/promises:133:25)
at Object.cp (node:internal/original-fs/promises:614:10)
at e. (app.js:1:550354)
at app.js:1:239608
at Object.next (app.js:1:239713)
at app.js:1:238629
requireBuiltin @ node:internal/bootstrap/realm:428
(anonymous) @ node:internal/original-fs/cp/cp:48
compileForInternalLoader @ node:internal/bootstrap/realm:398
requireBuiltin @ node:internal/bootstrap/realm:429
lazyLoadCpPromises @ node:internal/original-fs/promises:133
cp @ node:internal/original-fs/promises:614
(anonymous) @ app.js:1
g @ app.js:1
n @ app.js:1
Promise.then (async)
l @ app.js:1
g @ app.js:1
e.handleEvent @ app.js:1
click @ app.js:1
apply @ /Applications/Obsidian.app/Contents/Resources/app.asar/node_modules/@electron/remote/dist/src/renderer/callbacks-registry.js:54
(anonymous) @ /Applications/Obsidian.app/Contents/Resources/app.asar/node_modules/@electron/remote/dist/src/renderer/remote.js:353
(anonymous) @ /Applications/Obsidian.app/Contents/Resources/app.asar/node_modules/@electron/remote/dist/src/renderer/remote.js:335
emit @ node:events:519
onMessage @ node:electron/js2c/renderer_init:2
Can reproduce the issue, thanks!
Will be fixed 1.8.1
What is the ETA for release of 1.8.1?
The dev team doesn’t announce release dates ahead of time. Probably won’t be too long for a point release, though. :wink:
