Dragging a note link from a base links to the base, not the note
  • Create a base that includes note links.
  • Insert a transcluded link to that base in a note.
  • Drag any of the linked files in the base to another place on the note.
Yes
I used to do this all the time (before 1.13.4) and got a wikilink to the note I was dragging.
Now I get the base link transcluded instead. I replicated this in the sandbox vault, so it’s not my configuration.
Obsidian version: 1.13.4
Installer version: 1.13.4
Operating system: Darwin Kernel Version 25.6.0: Sat Jul 11 15:26:12 PDT 2026; root:xnu-12377.161.13~4/RELEASE_ARM64_T8142 25.6.0
Catalyst license: none
Community theme: AnuPpuccin 1.5.0
Plugins installed: 17
Plugins enabled: 16
1: Image Converter v1.4.6
2: Linter v1.32.0
3: Notebook Navigator v3.3.2
4: Outliner v4.10.2
5: TaskNotes v4.11.1
6: Text Extractor v0.7.0
7: Dataview v0.5.68
8: Advanced URI v2.0.0
9: Metadata Extractor v1.1.0
10: Fold Properties By Default v1.0.12
11: Backlink Settings v1.0.1
12: Note Toolbar v1.34.13
13: Omnisearch v1.30.1
14: My GTD v0.1.0
15: TaskNotes Workflows v0.1.1
16: Templater v2.25.0
Which type of links do you use, markdown links or wikilinks? It works correctly with wiki links.
Just for more context because we are both using the same version of macOS and Obsidian and dragging links works fine for me..
I have my options set to this and don’t have the issue you describe:
thanks
will be fixed 1.13.5 ETA unknown.
