I am using an editor Zenreader that can export reports from outlines in .md format. It exports the report as a single markdown file, and the images to the report are stored in a separate folder as PNG. The markdown file links to the folder images properly.
I exported an outline report to a folder on my desktop. I tried to drag + drop the folder into a folder in a vault in Obsidian. Obsidian would not accept the drag + drop operation.
Allow a user to drag + drop FOLDERS into a location in an Obsidian vault.
I can export the folder from the directly to the specific Obsidian folder at the system level. With this approach, the contents for the report are fully present and all links from the source .md report work automatically.
