Problem
I’m a bit of a newbie here. Trying to add a series of pdf links from obsidian file explorer into a document. The documents are embedded with the ![[name]] format, so display. Is there any way of dragging the documents so I only get the links? If you drag a list of pdfs I can edit the first one, but the second and subsequent ones don’t seem to have anyway of accessing the underlying markdown, so I can’t remove the ! from them. I can do it one file at a time though.
Searched forum and the help to see if this is possible, but not found anything about this topic.
