The drag and drop function of notes to reference to these notes works as it should. One addition which would simply my workflow would be, that you can drag and drop a note onto a word, and it pastes the link directly into the word.
If you drag a note over a word, it automatically pastes the link into the selected word, so that the word references automatically to the note.
I drag the note into my current note, delete the current word and add the word manually
