On the iPad, hitting enter once on either a hardware keyboard or on-screen keyboard on the iPad creates a double line break rather than a single. It also does not respect current bullet position but reverts the next line to being fully outdented without any bullet or check box
Please resubmit this bug report and make sure that: 1) you follow the bug report template, 2) you use the default theme (no css) and 3) there are no third-party plugins enabled (You can use the sandbox vault for 2 and 3).
Also this should be in the mobile category, search there too.
