I want to drag the object without creating a new one.
I’m not very skilled at using mouse.
While using the canvas,
if you press and release on an object,
it selects the.
Pressing and releasing again allows you to edit the .
However,
When I quickly press, release, press , and then drag the text box to another location before releasing, a new card is created.
I believe this is an issue with Event-driven Programming and doesn’t require details about my usage environment.
