Double click tab header to toggle pin
when you want to toggle pin a tab without having to use a shortcut
Double-click on the tab header. It’s really super intuitive to use, so I think it should be a default behavior
I integrated it to my plugin https://github.com/1C0D/obsidian-easy-toggle-sidebars/blob/master/src/main.ts#L383C1-L394C3
