Document goes blank on task switch away and back
I have an open document. I switch away to another task/app. When I switch back, the document is empty, except for the title.
I think that this began occuring after I upgraded to macos
open a document that has some content.
Switch away to another task/app using command-tab. Do some things for a while. Perhaps visit several apps. An immediate switch back does not usually repro the issue.
Eventually, return to obsidian with command-tab.
On a successful repro, the document appears to be empty. ctrl-z brings it back.
Did you follow the troubleshooting guide? [Y/N] Y
yes, restricted mode, default theme.
My full document.
the document is empty of content.
The problem may have begun after I updated to macOs Sequoia 15.0.1
It sounds like your vault is in iCloud Drive and iCloud is removing the files.
If so, right-click on the vault folder, whatever folder the vault is in, the Obsidian main folder, etc., and choose Keep Downloaded.
Screenshot 2024-11-30 at 10.05.21
Let’s see how it goes after doing that.
