<div> breaks links to headers
Insert a <div></div> pair into any note that has headers. Headers following the <div> tag do not appear in link autocomplete after typing #, and in fact can’t be linked to even if typed manually. If the <div> is at the top of the document, no headers will appear.
Behaves like this in the sandbox.
Headers are available despite the presence of <div> tags
Headers after <div> are ignored
Obsidian version: v1.8.10
Installer version: v1.8.4
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:33 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T8122 24.5.0
Base theme: light
Community theme: Cupertino v1.7.4
Snippets enabled: 1
Plugins installed: 33
Plugins enabled: 32
1: Dataview v0.5.68
2: Auto Link Title v1.5.5
3: Customizable Sidebar v2.2.1
4: Local images v0.14.2
5: Local REST API v3.2.0
6: Minimal Theme Settings v8.1.1
7: Tag Wrangler v0.6.4
8: Templater v2.11.1
9: Editor Syntax Highlight v0.1.3
10: Emoji Shortcodes v2.2.0
11: Iconize v2.14.7
12: Sort & Permute lines v0.7.0
13: Style Settings v1.0.9
14: Spaced Repetition v1.13.3
15: Homepage v4.2.2
16: Advanced URI v1.44.3
17: Excalidraw v2.12.1
18: No dupe leaves v0.0.12
19: Map View v5.5.0
20: Sheet Plus v1.11.9
21: Copy Image v1.1.0
22: Paste image rename v1.6.1
23: Ribbon Divider v1.1.1
24: Waypoint v2.1.0
25: Manual Sorting v2.4.0
26: File Cleaner Redux v1.7.0
27: WordCraft v1.1.1
28: Folder notes v1.7.35
29: Force note view mode v1.2.2
30: Number Headings v1.16.0
31: Text Format v3.1.0
32: Extended Markdown Syntax v2.0.11
Although it affects me, I think this is quite a low priority. It may be this is an unavoidable side-effect of mixing HTML spans in markdown documents, and if so, it’s not the end of the world if this behavior is just the way it is.
This is not a bug. We explicitly do not support intermingling block-level HTML elements (like div) and Markdown.
All HTML block-level code must be contained in a single Markdown block (that is, no blank lines).
Thanks, good to know, and that seems quite reasonable.
