A setting to display search results and backlinks in preview mode will make these more clean.
Just to add to this, opening a page from graph view in preview mode would also be good.
I would like an option to see the linked mentions in the central, main view (as quote blocks) in Preview mode rather than the raw markdown in the right sidebar
+1 to this. Same for the text / tag search.
I’ll suggest add a toggle to change the match in preview / markdown mode.
Hello, when i’m search for linked mention, unlinked mention or just search for keyword the preview are unrendered (We see “### Title”, “[[Link|text]]”, “- [ ]”, “-” instead of bullet list", metadata ect.
It would help me figure what i search and have a better view to understand that data it showed to me.
The text excerpt should look like in view mode and make avalaible to unfold sub bullet point in the search result. Could be nice too that when overing links showing preview mode but not a needed feature like the point before.
Looks likes roamresearch linked and unlinked mention style
Related feature requests:
+1. I would find this especially helpful on mobile. (I’m assuming the feature could be propagated to both desktop and mobile at the same time.)
I would also very much +1 this feature. The panes in which search results, tag list, links/backlings content etc. appear, have by themselves much less contrast and smaller character than the editor view. Thus, I would argue that especially here the rendering of content creates a huge, huge benefit. I frequently feel lost in the forest of syntax while trying to skim the content. Having this said, also the type of activity that you normally do on this type content - skimming - requires better orientation, facilitated by rendering. I normally do not become distracted by looking at markdown syntax, I even wrote my entire doctoral thesis in vim with pandoc markdown. But this is writing, it is a different, normally slower and more elaborated process than skimming across a long list of diverse content and looking for the one piece of information, or getting an overview. Rendering would make this a lot more pleasant.
Although I use Obsidian already quite some time I have rather seldom used the backlinks feature. Only now starting to realise how valuable it is, but also why I did not use it as much as I could.
The reason is the presentation. I have tried Logseq recently to see how that works and the backlinks work a lot better there because they are formatted and they only show the block where the backlink originates from.
Now Obsidian allows you to hover over the block to preview it but I would like to have an option to always show the backlink previewed and limited to the correct block (as it does already but only in edit format).
It seems like the code is already available. Just make the preview format the default for the backlinks and also show only the whole block that is referenced.
Im upvoting this and make it current. I really want the reading view formatting for backlinks (coz I use it alot). In fact I am use it also via embedded query, so it would improve my workflow even more.
Hope to see this in the trello roadmap soon :crossed_fingers:
@moderators I guess, title of this request should change from Display search results and backlinks in preview mode e.g. to:
Display search results and backlinks in "Reading view" mode
To keep it consistent with updated naming convention from Obsidian Release v0.13.8 (Insider build) :
  • “Preview mode” has been renamed to “Reading view” to avoid confusion.
+1
This is the feature I’ve been waiting for the most since the day Obsidian appeared!
It would improve so many features at once: side pane backlinks, in-file backlinks, file search, embedded queries.
Right now it looks, well, suboptimal, especially in bullet lists, since the indentation gets lost once the line gets wrapped:
And there are a lot of folks who use Obsidian as an outliner: the outliner plugin has more than a hundred thousand downloads right now!
The latest version of the Query Control plugin can now render search results in the sidebar search and in embedded queries.
The plugin adds an extra button to the nav bar which allows you to render your results. See the release notes here for more details: Release 0.3.0 · nothingislost/obsidian-query-control · GitHub
The plugin is still in early development but can be installed using the BRAT community plugin by adding the beta repository “nothingislost/obsidian-query-control”
Looks like the plugin development is somewhat haphazard. I also see the author resorting to monkeypatching to achieve this. This might be brittle, and besides, I just don’t see the point of having your search results not rendered.
Trying out the plugin makes it even clearer, that rendering search results is a much cleaner & user-friendly way of displaying them.
