When viewing high resolutions image attachments, Obsidian displays them very large.
If attachments contain “@2x”, “@1.5x” etc in their filename, Obsidian should adjust for the multiplier when displaying them.
Current workaround
Open image in another app to check the total pixels, then calculate the display size, adjust image display size in Obsidian by adding |nnn at the end of the link.
Related feature requests
I couldn’t find a similar request, but did find some documentation here about Electron and high resolution images.
At the moment I am working around this by defining a css class in front matter:
cssclass: RetinaImages
with the following snippet applying a zoom value to all images in that note:
.RetinaImages img {
  zoom: 0.5;
This works okay as long as the note only contains images are 2x scale.
But it would be so nice if there was a way Obsidian could parse the filename and apply an appropriate zoom value wherever it finds “@2x” or “@1.5x” etc
