Display abnormal for multiline link
I believe previous version of Obsidian did not have the issue and only lately I noticed it:
If you have a link where the display text is on multiple lines, while the link still works, the display does not look normal.
type in a multiple-line link, for example
[A long long text cannot be hold in one line
it has to go to the next lines
like this to Google link](https://www.google.com)
Note the link still works, and the text from the 2 lines are underlined
Obsidian version: v1.4.14
Installer version: v1.4.12
Operating system: Windows 10 Pro 10.0.22621
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Advanced Slides v1.20.0
Screenshot 2023-10-01 161853
I don’t think the editor ever supported this.
We definitely not support it for wikilinks.
Please, open a FR for standard markdown links. thanks
