We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
The bug is about ‘shift-key’: I can’t select multisentence by using ‘shift-key+direction key’.
It appears after update is finished.
- Operating system:
- Debug info:
