Disable scheme setting field for Dark/Light only supported themes
If any theme only supports a single mode (either Dark/Light), then the user is able to see the all the options in the dropdown field for the Base color scheme setting field under the Appearance section in the Obsidian settings.
As can be see in the following image, the Rose Red theme which only supports dark theme, but the user can also able to select the other options from the scheme field :
  • The corresponding option should be automatically selected for the Base color scheme dropdown value when the user switches the theme.
  • Possibly, the field can be disabled, so the user wont able to change that setting and a hover message can be shown, that the selected theme only supports dark/light scheme only.
Also, if the user has selected Light as the scheme, then all the Only Dark themes shouldn’t be shown in the Themes setting dropdown. (Although I dont know, how many users would like this feature.)
