Dialing a phone number from a note?
I want to be able to call a phone number by clicking on it in a note. Is it possible, and if so, how do I link it?
Depending on your OS, maybe? e.g. on iOS, I highlighted the number and scrolled to the right of the edit menu pop-up. One-click, I’m not so sure about.
Try the tel: URL syntax.
[888-555-1212](tel:888-555-1212)
On Android, long-pressing a number that looks like a telephone number will select the number and include “Call” as an option in the popup menu.
So yes, you will need to provide details on the operaing system where you want to achieve that.
That’s it! I knew I had seen that somewhere before but couldn’t find it again. That works on both my Mac and iPhone. THANK YOU!
