Please note: although this may seem like a niche problem, it is an accessibility issue.
Using standard text traversal and selection hotkeys is very important for dictation/voice users who do not have full use of their hands and for whom using a mouse to select text and navigate around text is impossible or physically painful.
- Create a new note with a long paragraph (a single line/block of text that wraps around multiple pseudo lines)
- Insert your cursor in the middle of the paragraph. So if your paragraph is 5 pseudo lines long, then insert your cursor in the middle of pseudo line 3.
- press
ctrl+up
- press
ctrl+down
In step 3, I expect the cursor to jump to the beginning of the block.
In step 4, I expect the cursor to jump to the end of the block.
This is standard behavior for most text editors. Compare to Microsoft Word, Google Docs, and Wordpad.
In step 3, the cursor jumps to the end of previous block. (This is quirky, but isn’t so bad.)
In step 4, the cursor strangely jumps to the first line of the block, into the column where the cursor was previously placed.
For example, if the cursor was previously in pseudo line 3, column 10, and then you repeat Steps 3 and 4, your cursor will end up in pseudo line 1, column 10. Very random.
Windows 10
Obsidian version: v0.13.14
Installer version: v0.10.8
Catalyst license: supporter
Legacy editor: off
Safe mode: on
Update installer: installer version too low, please download from Download - Obsidian and reinstall.
Additional
Cursor begins in middle of paragraph:
User presses ctrl+up and the cursor jumps to the line above the current paragraph.
Cursor strangely jumps to line 1, but previous column.
