Open the Sandbox vault in Obsidian
- By default, the sandbox vault opens
Start here.md, the left sidebar is open and the settingNative menusinAppearanceis enabled (at least, on MacOS)
In the top-right “3 dots” (
•••) menu ofStart here.md, look for the dropdownCopy pathand select the optionfrom system rootin it.
Yes ![]()
Like for the other options in the Copy path dropdown (as Obsidian URL and from vault folder), only a notification stating Copied to your clipboard should be triggered ![]()
A notice Copied to your clipboard does appear and then:
- While my mouse cursor is still sitting in the area where I selected the option
from system rootinCopy pathand without moving it anywhere close to the vault switcher/manager at the bottom of the left sidebar,Obsidian Sandboxis highlighted as if hovered
- A message containing the path of the Sandbox vault (from the system root) + the amount of files and folders it contains appears
Obsidian version: 1.12.4
Installer version: 1.11.7
Operating system: Darwin Kernel Version 24.6.0: Mon Jan 19 21:56:28 PST 2026; root:xnu-11417.140.69.708.3~1/RELEASE_ARM64_T6020 24.6.0
Catalyst license: supporter
Insider build toggle: on
- It only seems to happen if
Native menusis enabled in Obsidian’sAppearancesetting (I can’t repro if that setting is disabled
) - It also only seems to happen with the option
Copy path > from system root(I can’t repro with the other 2 options) - It does takes “some time” (1 second or less maybe ?) for the “hover” vault switcher message to appear
- It also doesn’t seem to happen if the left sidebar is closed. (Obviously
And here’s a screenshot of what I see after selecting Copy path > from system root in the “3 dots” menu of Start here.md
I didn’t move my mouse cursor/pointer at all after selecting the option … and yet, I’m informed that the vault is located at ~/Library/... and contains 31 files and 3 folders ![]()
