Delete a note with embedded files
There is a note. It has embedded files. These are usually images, possibly sound, etc.
Now, when you delete a note, all embedded files remain in the storage, which leads to a littering of the system
You need an additional feature so that when you delete a note, the embedded files are also deleted
You have to delete these files manually.
A post was merged into an existing topic: Remove unused attachments
