Dataview query for notes with yaml atributes using ISO "YYYY-MM-DDThh:mm"
I have been using a metadata propriety called “created”, that has the ISO format.
I use in every note in my obsidian
created: YYYY-MM-DDTtt:mm
The issue is, I have a note with a created attribute and I want to create a dataview in this note to filter notes that has the same values “YYYY-MM-DD”, but not the same “hh:mm”
e.g
I have a Daily Note with the yaml
created: 2023-03-01T00:13
and another note with with the following yaml
created: 2023-03-01T00:32
What can i made Dataview to recognize only the YYYY-MM-DD ?
dataview
TABLE
WHERE created = this.created
My understanding is that striptime is usually used to extract the date element from YAML date-and-time values.
For your syntax, the following should work:
WHERE striptime(created) = striptime(this.created)
But if what you have works as you need, just ignore this post. :wink:
Thank you. This works perfectly for me S2
