Dataview queries that use a variable defined elsewhere in a note?
I have a note that contains several dataview queries. I would like to be able to have each of these queries contain a statement like WHERE x, where x is a variable defined at the top of the note holding a value for a tag, such as e.g. #source/video or #source/article. This way I could easily pivot the multiple dataview searches in this note just by changing x at the top of the note.
The alternative of creating a separate note for each possible value of x is cumbersome, especially given that I change the dataview queries occasionally and would like to avoid having to repeat such changes manually across many notes each time.
Did an internet search for similar previous queries but didn’t find any.
if you use dataviewjs, you could poke a string into your query and execute that way.
For example, here’s a familiar query wrapped in dataviewjs
dv.execute('LIST FROM #todo LIMIT 5')
but you could just as easily add a variable from the page:
dv.execute('LIST FROM '+dv.current().x+' LIMIT 5')
assuming you had x in your frontmatter or as an inline variable and it was a valid source (in string form)
