Hmm it looks ok to me. Are you getting any output at all?
Is there a way to get file.mtime in āX days agoā format ?
Are you aware if thereās a way to query the vault for, all notes which contains a certain word in the title?
LIST
FROM ""
WHERE contains(title,"your_preferred_word")
This searches your filesā titles (as defined in the fileās metadata). If you are looking for file names, then adjust the last line of the code as follows:
WHERE contains(file.name,"your_preferred_word")
Don, this works great, Thanks! dataviewjs is a total blindspot for me, Iām not a dev.
P.s. how could I add an āorā operator this snippet? Iād like the option of tagging with either #WaitingFor or the hourglass emoji.
This query searches in all Dataview in-line fields ātitle::ā, but not in the note titles.
Yes - thatās what is meant by ātitleā (at least in my understanding)
But thanks anyway - I edited my above post to avoid misunderstandings.
thanks a lot, super helpful!!
Anyone know if it is possible to open the CALENDAR
query to a specific month/year? It opens to the current month by default, even if the where clause only references older notes.
IE:
CALENDAR file.mtime
FROM ""
WHERE date(file.mtime).month = date(2022-04-01).month AND date(file.mtime).year = date(2022-04-01).year
I think a simlple way is to use Number.
First, I think we donāt need the year and the day ,we only need month.
So,there are two ways
- 0 >= date(today).month - birthday.month >= -2
- date(today).month - birthday.month >= 10 for Dec,Nov to Jan,Feb
You can use that in where and connect by āandā āorā.Maybe itās easier to understand and maintenance.
Hi everyone. I am developing a Notionās like database using data view as search engine. I want to support inline fields edition but it is necessary to filter with the data view api just the inline fields. Is this feature supported?
thank you!
Anyone knows how to skip non-exist note in the FROM statementļ¼
I want to review my bad habit in my weekly note, yet I wasnāt writing journal everyday. As a result, I always get a prompt complaining about dataview could not resolve link during link lookup.
I used to create the notes I missed manually but it gets more and more annoying as my vault is full of empty journal notes now. So, I am wondering if there is a good way to skip the note that doesnāt existļ¼
Here is the query I wrote.
list
FROM
outgoing([[2022-05-16]])
or outgoing([[2022-05-17]])
or outgoing([[2022-05-18]])
or outgoing([[2022-05-19]])
or outgoing([[2022-05-20]])
or outgoing([[2022-05-21]])
or outgoing([[2022-05-22]])
and #Habit
And can dataview make a selection based on tags that have a dot in their composition.
I get this error
Dataview: Error:
-- PARSING FAILED --------------------------------------------------
1 | TABLE WITHOUT ID link(file.link, title) AS "ŠøŠ¼Ń Š·Š°Š¼ŠµŃŠŗŠø", status AS "ŃŃŠ°ŃŃŃ", priority as "ŠæŃŠøŠ¾ŃŠøŃŠµŃ", starttask as "Š½Š°ŃŠ°ŃŠ¾", duedate as "Š·Š°ŠŗŠ¾Š½ŃŠøŃŃ Šŗ"
> 2 | from ( #Š·Š°Š“Š°ŃŠø_Š²_firmc or #firmc ) and -#ŃŠµŃŠ²ŠøŃ and #m2m.firm.ru
3 | sort starttask DESC
Expected one of the following:
'and' or 'or', /FROM/i, EOF, FLATTEN <value> [AS <name>], GROUP BY <value> [AS <name>], LIMIT <value>, SORT field [ASC/DESC], WHERE <expression>, text
Can you tell me what the āconst data =ā statement would look like for this simple selection? My goal is to build a graph from the simple select but I need help with the syntax. Thank you
TABLE Rating as Rt from āDaily-Documentā WHERE Rating != null SORT file.name DESC
I have the exact same question as you. Have you found the answer yet? (with Dataview I mean)
How do you keep it from showing every day instead of just the days with symptoms tracked?
No. I donāt have the answer yet. It seems like other people know how to do this. There have been a few examples but I have not seen the code yet. Chart - yes - code no. It is holding me up from developing a cool dashboard. Is there anyone that can help us out? Thank you
Hi @Saorsa, if I understand what you are asking then that is easy. You just use the != null
Here is my data view for āRatingā. I rate most days and this excludes the days I forget. The data comes back perfect and it would be great to be able to create a bar chart by week and month so I can visualize the rating over time. If you see any code like that let me know. Thank you
LIST Rating
FROM "MobNotes"
Where Rating != null
SORT file.name DESC
Thank you for your your response. Originally I had the following
list link(rows.file.link, rows.symptoms)
from "03 Cycles/Yearly Navigation Note/daily"
group by dateformat(file.day, "DDDD") as Date
where any(rows.symptoms)
sort rows.file.ctime desc
which give me
So, I tried your suggestion as follows
where Symptoms != null
which gives me
I canāt figure out why it wonāt work
Quick note: The order of your operations matters: starting with FROM they happen top to bottom. (The first line, with list, is special since it controls the display of things after you have found them.) Your line with where Symptoms != null
should come right after the FROM line, before the groupby. I donāt know if that will solve everything, but hopefully itāll get you closer to solving it!
