What is the exact syntax (including the dataview part) to make this work?
Also, do we need to change the default date format?
Just put the code shown into a dataviewjs code block (instead of dataview).
No. But there are cases where it is extremely useful.
Be aware that the code shown by @AutonomyGaps will pick up any file in the vault that has something in its title that looks like a date to Dataview. If you donāt want that, you can specify a folder name inside the dv.pages() line, in the form of dv.pages('"Daily Notes"').
Docs on Dataview here: https://blacksmithgu.github.io/obsidian-dataview/docs/intro
I am getting this error message:
Evaluation Error: TypeError: Cannot read property āisValidā of undefined
at DateTime.equals (eval at (app://obsidian.md/app.js:1:1153594), :7732:34)
at eval (eval at (eval at (app://obsidian.md/app.js:1:1153594)), :9:27)
at Array.filter ()
at Proxy.where (eval at
Hi, this is great.
Iām trying to do a similar database but for research purposes.
In the image below, a database of images.
I tried to add the image-preview in the table using the HTML format in the frontmatter or in inline field (something like <img src="file:///Users/......"> ) and it works⦠But the table turns unstable and when it does an automatic refresh the table presents some glitches (a kind of āshakesā, as a graphical issue).
Now Iāll try to use your format ("") and verify if the graphical issues gone away. One question: what kind of link you put in ācoverā property?
Didnāt try @AutonomyGapsā new code, but let me check in my vault. What version of Dataview are you using, and which version of Obsidian?
EDIT: RESULTS
I found that I got the same error as you, had to leave the note and reopen it a few times and wait some minutes until it worked. The error occurs when file.day canāt be populated (because the file has no recognized date in the title, and no date: YYYY-MM-DD frontmatter field).
I have this now, and it works (the file is also called 2021-05-23 Test DataviewJS AutonomyGaps, to provide a date to file.day):
# 2021-05-23 Test DataviewJS AutonomyGaps
file.day: `=this.file.day`
file.mday: `=this.file.mday`
file.cday `=this.file.cday`
```dataviewjs
// default dateformat in case itās forgotten in front matter
var dateformat = "YYYY-MM-DD";
if (dv.current().dateformat) { dateformat = dv.current().dateformat; }
dv.table(["File", "Last Modified", "Date Created"],
dv.pages()
.where(p => p.file.mday.equals(dv.current().file.day) || p.file.cday.equals(dv.current().file.day))
.sort(p => p.file.mtime, 'asc')
.map(p => [
p.file.link,
moment(p.file.mtime.toString()).format(dateformat),
moment(p.file.ctime.toString()).format(dateformat),
ā```
(Note the last line ``` is faked for the forumāremove it if copying, and use real 3 backticks.)
Result:
all the latest versions
Saying ālatestā is always bad if people come here months after ⦠using numbers is preferred.
Btw, I used Obsidian 0.12.3 and Dataview 0.3.9 for this test.
@yalcin @AutonomyGaps It seems Dataview sometimes doesnāt āseeā the latest, probably due to Obsidianās rather effective caching. In my case, I sometimes had to wait a few minutes, or close & reopen Obsidian until all was seen again (especially when renaming the note that has the code).
To make it more user-friendly, even if the current note doesnāt have a valid file.day, you could change the code like this:
dv.pages()
.where(p => dv.current().file.day && (p.file.mday.equals(dv.current().file.day) || p.file.cday.equals(dv.current().file.day)))
.map(p => [
p.file.link,
Study the where clause: We only do it if file.day is valid.
On a note that has no date, you would now of course also get no results. But also no error message. (I removed the date from the noteās title for this test):
I just use a regular link in the cover property. I copy the image URL from Amazon and stick it in there.
Thanks so much for your fine-tuning of this!
Thanks. Regarding the mentioned graphic issues, this seems to indicate that there is a difference between links to local files and URL links.
I have a simple table to collect my journal entries related to a given book. Iām trying to have one of the columns show a link to the heading where I wrote the entry:
table Chapters, file.link+"#Reading:: The Lost Symbol" as Link from #my/journal where Reading="The Lost Symbol" sort file.ctime asc
And it results in this
Instead of resulting in a [[2021-05-23#Reading The Lost Symbol]] link, it gives me a separate text ([[2021-05-23]] reading ā¦)
Iām not very literate in codes, but Iāve been studying the documentation to see if thereās a way to achieve this. Do you guys know if itās even possible?
Nevermind: found the answer here: Dataview plugin snippet showcase - #158 by jyrodgers
I want to do this (extract data from a field for use in the query) as well.
Context: I want to make a query that shows people I havenāt contacted in a defined amount of time. The people have a field ādesired contact frequencyā and in it is ā2 weeksā or ā2 monthsā, whatever. The query:
TABLE
context, file.mday AS "Last Contact"
FROM "3 - Resources/People"
WHERE desired-contact-frequency AND file.cday <= date(now) - dur(1 week)
SORT file.mday ASC
^ Works
\/ Doesnāt work:
TABLE
WHERE desired-contact-frequency AND file.cday <= date(now) - dur(desired-contact-frequency)
SORT file.mday ASC
Thereās probably a way to do this in the js version, but 1) Iām not capable of that and 2) it seems like if thereās a way to access ādesired-contact-frequencyā this is a much simpler format.
Instead of this, could you try,
"[[" + file.name + "#Reading:: The Lost Symbol]]"
You can even add alias to the link if it gets long like,
"[[" + file.name + "#Reading:: The Lost Symbol|The Lost Symbol]]"
Oh! It worked. Thatās amazing, thanks a bunch, Rishi.
Hereās a snippet I use to make lists render as comma separated items instead of bullet points:
dv.table(
['File', 'Connections'],
dv.pages('[[Foo]]').map((page) => {
return [
`[[${page.file.name}]]`,
page.file.outlinks
.reduce((acc, outlink) => {
acc += `[[${outlink.path.replace(/\.md$/, '')}]], `;
return acc;
.trim()
.replace(/,$/, '')
Now this is very close to:
Table file.outlinks as Connections
From [[Foo]]
Except that the list renders differently. Obviously that is a lot of code to write just for a format change, but I like how the table looks quite a bit more with that.
Hereās a slightly cleaner version with .map():
dv.table(
return [
page.file.outlinks
.map((link) => {
return `[[${link.path.replace(/\.md$/, '')}]]`;
.join(', ')
But all are superseded by @Rishiās suggestion of the undocumented join():
This should make them identical,
Table join(file.outlinks, ", ") as Connections
From [[Foo]]
This function needs to be added to the docs still but you can find the relevant discussion on Github.
Awesome!
Hi everyone!
Iād like to implement a GAO (Got Aware Of) tracking system.
For any book or website, one note containing several records of type
GAO:
When: [[2021-06-02]]
What: [[Topic-name]]
Then, in each daily note, something like
```dataview
LIST GAO.What
FROM "Resources"
WHERE GAO.When = this.file.name
But this, unfortunately, doesnāt workā¦
Is this possible somehow? Any idea?
Thanks in advance.
ā
silvio
Could you try,
WHERE GAO.When = this.file.link
