Also, while you are in the dev tools, you could check the Console tab, and see if you get any errors.
Thanks for all your help. It is now fixed.
What I did:
I used the Atom Editor to correct the inline Properties I had throughout my Vault. (changing "Class:: " to "Class: " etc)
I created a new vault which I called “test_vault” and opened the developers console to watch for errors as I moved copies of my notes into this new vault.
I also created a dataview query and watched if it continued to work as expected as I moved notes into the new vault.
Eventually I found a note that created many console errors of “files that could not be found” so I isolated this note. In any-case this note did not impact the running of Dataview in this vault.
My original Vault (where Dataview did not work) still did not work. I used your procedure of opening the Dev Console and under applications, erasing the “IndexedDBs” starting with those of dataview. Once they were all erased, I restarted Obsidian.
Both my “test_vault” and my original Vault now worked with the Dataview plugin. I think that my inline properties which were not too consistent, broke the Dataview plugin.
Thanks for your help!
Awesome that you detailed all you did! I’m sure that will help others!
