Hi! I’m trying to use dataview to list lines tagged with #idea with a link to the note at the end. The query I wrote (I found here in the forums) is not scanning my entire vault and therefore I only see a partial list of items tagged with #idea.
I use Obsidian Sync.
Here’s the query:
list without id
L.text + " " + link(L.path + "#" + meta(L.header).subpath,"(link)")
from ""
flatten file.lists as L
where contains(L.tags, "#idea")
The query you present is specifically made for matching on bullet points, or lines within lists. So a random line in a paragraph tagged with #idea wouldn’t be caught, for example.
And what does the L.header refer to, does every item in your list have a header field?
Thanks for helping here! You’re right, I was expecting the query to pick any lines with the particular tag, but now I see that it works when the tag is part of a list or a bullet point.
I had just copied the query from another post and tinkered with it without really knowing what I was doing , I have now removed the reference to L.header since it’s not applicable to the way I take notes.
Thanks again!
