Dataview JS Headers are indented
Hi,
I have two H2 headers here. Once is a regular markdown H2 and the other is generated with DataViewJS
As you can see the one generated with DataviewJS is indented. Is there a way to get it aligned with the regular markdown H2?
Here is my DataViewJS script:
dv.header(2, "This is from dataview!");
Both inline and code block js queries look alright over here using the default theme and no snippets:
# This is not from dataview h1
`$=dv.header(1, "This is from dataview! h1");`
`$=dv.header(2, "This is from dataview! h2");`
~~~dataviewjs
Screenshot 2023-10-21 070520
Perhaps your theme or some custom CSS is causing the issue?
You are probably right. I’m using the minimal theme perhaps something in there. I’ll take a look.
