I have an home inventory folder in which each note contains the same key:values set, among which Room, Category and Cost.
I know how to produce a table showing the count and total cost of items in each room or category:
TABLE length(rows) AS "Count", sum(rows.Cost) AS "TotalCost" FROM "Inventory" GROUP BY Category
However, for some items, there is no value in front of the Cost key because it is unknown or not assessed yet, in which case DV seems to exclude the whole Category or Room from the table.
Is there a way to tell DV that any missing Cost value should be considered zero $ instead?
Thanks!
