Dataview: How to apply function to all rows in array after using GROUP BY command
I have a dataview table with a column where I calculate the time since a date as
date(today) - date as Since
I want to use the GROUP BY command on the table, which changes things into arrays. I’ve figured out how to make the other columns do what I want by appending rows. to the field name, but I can’t figure out how to do the same thing with the “Since” column.
I only have very basic programming skills, which I assume is the reason I can’t figure this out. From searching online it seems like I need to use a forEach() method on the array but I can’t figure out how to do that properly. I looked through forums but I can’t find any other posts discussing this specific issue. Thanks in advance!
You could most likely do something like:
map(rows.date, (d) => date(today) - d) as Since
If you need access to more than one of the fields in a row you could try to do:
map(rows, (r) => date(today) - r.date) as Since
Thank you for your help! Those both work.
