I try to create a table with group by tags.
In my files, the yaml section looks like:
tags: [tag1, tag2, tag3,...]
To display my table I use :
table without id tags,rows.file.link
from ...
group by tags
My issue is that the “group by function” is displayed by a list of tags and doesn’t group by each individual tag :
Is that how the “group by function” behave or is there a solution to display files by an individual tag?
Hi.
Your tags in each file are a list of tags. So, to group them individually you need to flatten them before group them. Try this
TABLE without id tags,rows.file.link
FROM "folder"
FLATTEN tags
GROUP BY tags
Thank you !! You rock !!
