On macOs with default file system (non case sensitive) - the Daily notes plugin New file location preference is case sensitive when creating new daily note.
Reproduce:
- Set daily note file location preference to
daily/
- Rename your daily notes folder for
Daily
- Make sure todays daily note does not exist yet
- Create daily note
creates new empty daily note
Errors with Failed to create daily note. Folder "daily/" not found!.
- Operating system:
macOS 10.15.5
- Obsidian version:
0.7.3
- Using custom CSS:
No
